#142766
Gas motor should do
#142768
Just kidding. But your going to need to give us some more to work with. What are you trying to accomplish? More speed? longer run time? Talk to us! :D
#142780
As I said in my other reply i'm not all that familiar with the ride your talking about. But I would assume that if it's already operated on 24/36V system its run by use of an ESC if you look up 48V/100 amp cpntroller on ebay you will probably find one .. you might want to look into motor to match up as well, bu thats just my opinion. if your ride is 24 or 36 v you will also need to add in the extra battery or batteries to reach the required voltage.
LED Lights
Recently I chose lighting for my boat. A friend ad[…]
On board generator idea
looks great
In high you should have 12v to each motor (paralle[…]
Got the kids in it after messing with the exhaust.[…]
