By Smacias
#144237
I would like to make my daughter's quad to go faster but I don't know we're to start? The quad that she has is 12v. I got it when she was 3. Now she is 5 and she really wants to go fast..lol.. any ideas?? And how to do it. Thnks
#144238
Depending on what quad it is, you can usually add a 6v battery in series to make it an 18v ride. Speed is greatly improved but with added voltage and the weight of a 5yr old things will eventually break. It's just the way it is.
By Smacias
#144240
It's a barbie kawasaki 12v quad. The battery is under the sit. And it looks like theres no space to add another battery. Any other ideas? Thnks.
#144241
Oh there's room. You just gotta go a little tetris on it. The stock battery will get replaced with either a 12v 12ah (12 volt 12 amp hour) battery along with a 6v 6ah battery or three 6v 6ah batteries. you can use smaller batteries of a lesser amp hour rating but with the added voltage comes higher amp draws which lead to shorter run times and run-on sentences.
You will need to install a 40 amp in-line fuse.
Check it out:
http://www.modifiedpowerwheels.com/foru ... IC_ID=7046
#144244
Sorry but I can't help you with that one.
Low voltage warning
Building a new pool
Lightning McQueen lowered
