By Superfastjack
#150654
Hi-
I’m new here. Are there step by step instructions on how to upgrade our Kawasaki quad to speed it up a bit? I’m not looking to get super crazy.
Is there a resource that tells you exactly what to purchase and where?
Thanks!
#150711
Check out the "up to 12v" section under the battery/electrical tab on this site. There's quite a bit of info there. Adding a second gearbox/motor and then running at 12v is a common upgrade.
#150799
I purchased a 12v battery from amazon and a 30amp in-line fuse. Hardest part was cutting out part of the frame which i did with a hacksaw blade. I made a bracket to cradle the bigger battery out of 2” x 1/8” aluminum stock.
Our two year old can pop small wheelies now!
"Best Choice" Jeep?
I'll look and see what I can find but a quick goog[…]
16v battery replacement
Sturgeon866, Wondering how your car is running n[…]
More torque
I'd second the recommendation for 775 motors. Alt[…]
