By toothlessdog
#150544
hey, would a relay cause a parasitic drain? Im currently reading 0.15 amp when doing battery drain test with the connect switch off. Once I disconnect the relay, it goes to 0.0.
Relay is connected to a 2V 3A Car Blue LED Light Power Metal Push Button Toggle Switch that would power a small car radio when switched ON (only thing connected to relay) . I have disconnected power cable from radio to test, and still getting same amp drawn with switch off, I have also tested by removing the relay and amp usage goes to 0. Is this normal, or do i have a faulty relay?
thanks
By CJB
#150550
A relay should not draw any current unless the coil is connected to both +12v and Ground. Not that I'm aware of anyway.
If you can figure out which relay is causing the draw you can try a new relay there and/or troubleshoot down the lines connected to that relay.
https://media.giphy.com/media/8okbmh3Q2c89O/giphy[…]
Help! Newbie
If you have 12v coming out of a battery but no v[…]
Contact peg perego and they will send you a replac[…]
Also, I want to mention that 2019 will be the last[…]
