By pjku79
#80994
Bare with me because I am new. I bought this jeep hurricane for my son and it drove find for a while. Over the weekend the reverse stopped working. I took the center consol a part and was playing with the switch. I unplugged the two connectors to see if they were corroded and plugged them back in and it started working. Thought I had it fixed but when I installed it back in the reverse didn't work again. I read some where that you can rebuild the switch, but couldn't find a post with directions. I am guessing it is the switch that is causing the problem or maybe I have a bad wire connection some where. I guess I am looking for two things. First directions to how to rebuild the switch and second a wiring diagram so I can test wires. Thanks in advanced.
#80995
Check the FAQs. I believe the topic was titled "switch maintenace" or something along those lines.
#80996
Circuit breaker popping
