By Jakehite12
#146362
I have this fourwheeler for my little sister that when I press the pedal a light comes on but it will no accelerate. I took the pedal apart and unhooked the red and yellow wire and hit them metal to metal but it still didn't move so I don't think it's the pedal. Can anyone please give me some advice.
#146366
Is the light you mentioned the battery meter on top of the tank? It should light up with a few lights from red to green, showing a fully charged battery. Do you see the full range of colors? Have you charged the battery and tested the voltage?
By Jakehite12
#146370
Yeah those are the lights I'm talking about that light up. They say fully charged when I press the pedal which should be right cause it's been charging for a while. Have any suggestions???
Another option to consider for the future... De[…]
Thanks Wesley -- good point that not everyone want[…]
Thanks
powerwheels Bigfoot
Not metal frame. Needs wiring replaced. Melted fr[…]
