By CB2K
#147335
My sister handed down a F150 power wheel to my son. I believe the battery is dead because it charged for 20 hrs and when I put in the truck nothing happened.
Now looking to replace the battery, but have a few questions.
I want to use a 6v sla battery, can I cut the connections from the stock battery and add them to the new sla battery?
Will I need a fuse?
Will the stock charger charge a 6v sla battery?
Thanks in advance. If I’m going about this wrong please let me know.
#147337
Q: I want to use a 6v sla battery, can I cut the connections from the stock battery and add them to the new sla battery?
A: Yes you can use the stock connector/plug
Q:Will I need a fuse?
A:Yes. Start with a 30amp fuse but you can safely move up to a 40amp fuse if needed.
Q: Will the stock charger charge a 6v sla battery?
A: Yes the stock battery is an SLA battery so the stock charger will charge an aftermarket SLA battery. It's a slow charger and a smart charger is recommended.
You have it right. If you need anything else just ask. That's what this community is all about. Helping each other so we can spend quality time with our kids.
R/C Mustang for James
