#148076
Only shorts when you press the pedal still? Can you post some clear pics of your wiring? I'd like to help but very hard to do without more info.
By chart2006
#148093
I responded to your message but I wanted to try and make it a bit clearer so I wrote down exactly where each wire goes. As mentioned in my message you'll want to determine which way the switches are facing so check for continuity or a short between the terminals. If you're looking directly at the terminals on the shifter the terminals/switches should be in the below layout where the (U) is the upper switch and the (L) is the lower switch - rotate the above image clockwise 90 degrees in your head. I've included a layout for the pedal as well. The dashes (-) denote shorted terminals so make sure you check the switches. The shorted terminals on the pedal are usually the two terminal nearest to each other. Also just remember to test the motors with the shifter positioning to ensure the motor polarity is correct. Also remember the polarity of the right motor is opposite of the polarity for the left motor.
U1 - U2 U3
U4 - U5 U6
L1 - L2 L3
L4 - L5 L6
P1 - P2 P3
1. U1 <--> U4
2. U2 <--> Motor 2
3. U3 <--> L1 & Motor 1
4. U5 <--> Motor 1
5. U6 <--> L4 & Motor 2
6. L1 <--> L6
7. L2 <--> P2
8. L3 <--> L4
9 L5 <--> P3 (optional resistor) & battery
10. P1 <--> battery w/ inline fuse
By d00mzDav3
#148132
I kept trying to fix the things that were messed up and it was just bad quality work all around. After i re read all the information you provided I realized I could start from scratch and do it right. I did that and it works great now. Thank you very much, your input was above and beyond what I expected, and you made a little boy very happy. If you have any personal training questions Let me know lol. Thanks again though, your time and attention to detail is greatly appreciated!
By Robert
#148900
Glad to hear you got it working.
Was your final wiring 12GA or 10GA?
I did a LMQ Super 6 Mod to 18v and was having similar fuse issues until I changed the FULL wiring harness to 10GA.
Need a help
