#148049
Hey guys,
I recently painted my sons jeep. It sat out in the rain over the weekend while I was gone. We put It back together yesterday. I charged the battery this for a couple hours, plugged It up and no luck.
Battery had power. I checked the cables with the tester... put I.T to the orange and red (coming from front) and the black (from battery) hit the pedal and got voltage. Other than those two which are obvious I don’t know what else to check.
The Jeep does not move whatsoever... any advice appreciated
https://imgur.com/a/8rVYY
#148052
Sounds like either a bad pedal switch or a bad terminal/connection. Circuit is carrying voltage but not supplying current. Can you unplug the pedal switch and use a jumper wire to simulate the switch and get it to work? Another thing to question is the battery. They fail without warning sometimes. Jumper voltage straight from battery to the motors and make sure they work.
#148153
I have little experience using the voltage meter. I tested the pedal cables and they seem to be getting power, even when pressing down on the pedal. I ran straight power to the motors and they both worked... this was all after replacing the shifter which was in bad shape . I don’t know what else to check?! Could it be the wiring ??
Wow. Looks like those bike tires were custom made[…]
Date code decoder?
Also compliments of hobby masters. If you find the[…]
