By Web3482
#148182
I recently replaced both motors and gears boxes with ML Toys upgrades equip. Ran for month or two and died. Began replacing plunger switch and gear shifter. When replacing gear shifter I noticed the one from factory has an added contact on exterior with black (ground?) wire attached. The replacement has nothing in this location. I’m guessing I have an older gear box but can I replace it with new one? Thanks
#148186
The black wires are from a smaller internal switch that send s the fwd/rev signal to your dashboard lights/soundbox. You could just replace the main switches and retain your original shifter housing along with the small fwd/rev soundbox switch.
#148191
Replaced switches in old housing with switches from new one (turns out new housing was too big to fit anyway). Have forward and reverse but not two different forward speeds (lo/hi). Tried different positions of switches and plugin orientation but still only had (1) forward and (1) reverse speed. Both switches to rear I have reverse. Both switches to front I have forward gear. Nothing when one is forward and one is back. Pulling my hair out lol.
Date code decoder?
