Putting two 12v batteries in mustang (series or parallel)
Posted: Mon Feb 12, 2018 12:39 pm
by Stevenanto
Good day everyone,
I’m a newbie at this. I recently bought a mustang with smart drive for my son,he does drive it in the house for now but in the summer he will be using this outside. He’s been driving it since he was 16 months old, he’s now 18 months and he actually knows how to steer and control lol.
Anyways back to my original question, I currently have two power wheels 12v batteries. I know that if I wire them in parallel or series it will either increase power or drive time.
Currently I would like to increase the drive time, how would I go about wiring it? If I wire it a certain way would I be able to charge both batteries at once? Is there currently any diagrams online? Has anybody done this to this type of mustang before?
Re: Putting two 12v batteries in mustang (series or parallel)
Posted: Mon Feb 12, 2018 7:29 pm
by Bigmac41288b
Parallel increases AH (Runtime)
Series increases VOLTS (Speed)
Not sure if the smart drive can handle a voltage increase but runtime increase shouldn’t hurt.
I usually just run one battery at a time and keep the others on charge when I’m close to home. I do have one or two with a couple onboard batteries to increase runtime for walks to the park and such when I don’t have extra batteries close by.
Posted: Mon Feb 12, 2018 9:16 pm
by lexx0116
Stevenanto wrote: Currently I would like to increase the drive time, how would I go about wiring it? If I wire it a certain way would I be able to charge both batteries at once? Is there currently any diagrams online? Has anybody done this to this type of mustang before?
For charging, use parallel setup so both batteries will be charged at the same time.
Posted: Tue Feb 13, 2018 7:26 pm
by Stevenanto
Thank you both so much for your help and advice. Much appreciated.
Posted: Tue Feb 13, 2018 11:50 pm
by Hammer-fm
In case you hadn't already decided this: based on the experiences posted here with other circuit-board based vehicles, I wouldn't recommend trying series (24V) connection on this (smart ride) one. It's unlikely to be designed to handle that voltage. You've got at least a year or so before you need more speed, hopefully :lol:
Posted: Fri Feb 16, 2018 6:49 pm
by Stevenanto
Thanks hammer.
I’m guessing if I would upgrade to 24v, I would need a new motor
Posted: Sat Feb 17, 2018 1:22 pm
by Hammer-fm
The concern isn't just the motor -- it's the speed controller board inside. The regular/crude/basic Power Wheels (without SmartDrive) just have switches and wiring, and the main problem with running higher voltage there is that you eventually overload those and they burn out. That is a mechanical failure and won't happen immediately unless you do something really ridiculous. The motors are typically the first thing to go since they're where most of the heat builds up.
However, with the SmartDrive speed controller, the board is likely designed specifically for 12V usage and the semiconductor components inside will fail basically immediately if you apply 24V. I haven't seen any pictures of the actual board (I'd love if someone could post a high-res one), but I would expect the budget-cutters would have squashed any over-engineering. I'd expect 16 or 25V capacitors (24V batteries run ~13.2V at full charge), 20V FETs, etc, for cost reasons. It's possible they're using an off-the-shelf design that IS designed for higher voltages but it isn't very likely.
So I'd expect running 24V on that ride (reliably) would necessitate replacing the motors, but much more as well. There are other options: eg. it will probably work ok with a faster 12V motor (eg. the $3 Nichibo 550-series 23k RPM one I posted in the gearbox/motors section), and that could get you a ~50% speed boost with the same 12V input.
Posted: Tue Mar 26, 2019 9:58 am
by Stevenanto
My son is only 2 and a half and he seems bored with it. I'd like to make it go faster for him. So you think a motor would do it?
Posted: Tue Mar 26, 2019 2:29 pm
by M.L.Toys
If you're running 24v in series put in a set of Staqge IV Motor/Gearboxes: https://www.mltoys.com/category-s/118.htm
If he needs more speed then that it's time for a go-cart or quad!
Posted: Tue Mar 26, 2019 7:09 pm
by Stevenanto
thanks, ill look into that! ive seen tons of videos where kids are flying in these little rideones and doing burnouts lol. my son would love that.
Im currently running 12v with the stock power wheels battery. i think that if i run it with 24v i would burn the control board or motor, ready to upgrade other parts in it so my son can have more fun.
Posted: Wed Mar 27, 2019 5:55 am
by M.L.Toys
Only the Smart Drive Mustang has a control board in which case you're stuck at 12v. Standard Power Wheels Mustangs no problem. Yes, you'll fry your stock motors at 24v.
Posted: Wed Mar 27, 2019 9:20 am
by Stevenanto
darn ive got the smart drive.... guess i have to get a new toy for my son
