#148660
Anyone have experience adapting this for power wheels usage?
Seems like it would be great solution. Good capacity, light, protection circuits. Would just need to wire a ec-5 to power wheels adapter. The only thing I'm unsure of is.....is it safe for power wheels amperage draw for extended time usage?
DBPOWER 600A Peak 18000mAh Portable Car Jump Starter (up to 6.5L Gas, 5.2L Diesel Engine) Battery Booster and Phone Charger with Smart Charging Port (Black/Yellow)
#148671
Here's things I consider, that's an 18ah starter pack, I'll have to later go out to the shop and look at the actual battery in one of the jumper packs I took apart when it quit working. They have a circuit board in them to boost starting amperage enough to start. I wouldn't know actually this configuration for constant prolonged use would last, as on a full charge, my newer booster pack now still only will last so many tries to provide the starting amperage when I use it to start a dead battery in a vehicle, all together probably less than a minute of cranking.
#150046
Well I spent a small fortune on a dual battery system in my 80, so I probably wont using it for jump starting; and another small fortune in a CO2 bottle system, so using the little air compressor is out, BUT....just about everything electronic nowadays is USB. So if you like to retreat to your tent and use tablet or phone it is awesome. I use it to power a portable DVD player in the tent sometimes. Depending where we camp and I use a cot or a tent / air mattress set up, taking the unit into the tent to fill up the mattress using my Coleman 12v air blower is priceless. it's a lot easier to fill a mattress up inside a tent then dragging it to and from the rig. I recharge Streamlights with it at my side rather than at the rig. This one, for the price is very well built. I've had it 2 years now and taken it on over 20 outings, never had an issue. My wife is now using it to charge her cell phone at the couch (Picture) since the phones cord is short and a wall outlet is not within reach. I'm sure the Duracell one is kool also.
#150470
Sorry, this is something off topic but I want your help regarding air compressor, I want to buy an air compressor for my workshop/garage which should be easy to use and should be priced economically. I have read this post https://www.consumersbase.com/best-air-compressor/ where I have found two types of air compressors Makita MAC700 and Makita MAC2400. Suggest the best one out of these .
3B Gearbox on 12v?
Repair Question
