By Tex1
#148764
Hello,
we have a A151 Gaucho that I modified taking it to 24V and ESC. we're happy with the perfomances.
Well it's not a A151 anymore actually, becasue I used the floorpan and the gear lever from a later generation one afte rthe original floorpan cracked. Anyway.
The new gear lever sticks in reverse, it doesn't return to 1st by itself. This makes reversing and looking back easier, but it makes possible to forget which way you're going to launch. So, my son asked me for a telltale light on the dashboard to light up when reverse in engaged - of course, BEFORE any current gets to the motors.
Is there any way to cleanly install it? I don't think there's a way to use the original front/reverse switch, is there?
Thanks for any ideas
Date code decoder?
