By adamrice
#148816
I picked up a Step2 xtreme cruiser for cheap. It's missing its batteries, and the charging-port connector has been cut out entirely.
This originally used 2 x 6V batteries that connect to two separate sockets in the battery bay, but the wiring elsewhere uses a 3-blade connector (which makes me wonder if it's got 2 hot paths and one return path). I've posted some photos. I don't mind bypassing the bay connectors and going straight to the underside connector if that makes more sense.
If anyone knows/can guess what kind of connectors these are, I'd appreciate the info. I've been trawling through the FAQs so I don't blow myself up. I'd be content to run this at original speed, but if I can make it go faster, so much the better.
Thanks.
