By Brock92
#148839
I have a few questions if anybody could help answer them please
1) I have a 12V 15Ah battery already but im having trouble sourcing a 6V 15Ah battery.
Would it be ok to use a 6V 12Ah battery instead?
2) The Ford Ranger comes with a remote, would the control board be able to take 18V without getting fried?
Thanks in advance for any help
Brock92
By gerd1986
#148844
Hi Brock,
I'm new here but been researching for a while, I'm sure someone else will come along soon but if it helps this is what I have so far for the same car:
1) You can't use a different ah battery, they need to be the same. You can use a different voltage as you have tried to source.
2) As far as I know it won't be able to take the voltage, or maybe it will but you are asking to have to buy a new board. To upgrade to 18v and keep the remote, lights etc you will need to wire in some relays as per this post:
viewtopic.php?p=131471#p131471
I hope this helps you.
By Brock92
#148848
Thanks for reply Gerd,
I have managed to find 6V 15Ah battery.
Thanks for the link to other thread.
I wonder could I just replace the relays in my car with 24V ones and would 18V from battery run them?
Date code decoder?
