By siego99344
#148873
hello you all am a first timer here. i took apart my sons jeep hurricane power wheel. because it wasnt going in reverse took it apart the console cleaned the connections.. now the issue reverse is forward and forward is reverse... i have messing around with it for over 3 hours and i can not find the right position for the switches. anybody pleas help me am aboput to pull my hair out..... thanks
#148874
Assuming you have a stock battery and connector (and have not removed gearboxes or motors), It sounds like one of the switch's connector is backwards (upside down).
By siego99344
#148877
hello and thanks......yea everything is stocked havent touched nothing. i didnt remove anything of the switches it wasnt going in reverse and i just opened open the stick and cleaned around it.. everything stayed the same nothing i moved. now its either going forward in reverse or reverse in forward and boy its frusterating,... i dont no what else to look at...
By Bigmac41288b
#148879
Do you have two speeds in reverse (High and low) and one speed going forward (low)?
Cruisin McQueen (nz)
NICE ... that is sweet.
PW Dune Racer
