By IWontPanic
#149026
I'm planning on modding an F-150 Powerwheels truck to Arduino driven electronic controls for both speed and steering. I'm a software engineer so programming the Arduino isn't a concern, but the I have to admit I'm out of my comfort zone with wiring and electronics. I could use any input on the wiring of this project. If I'm wiring something wrong, or should be using other/different components - suggestions are welcome!
I've been reading these forums for days, and been all over the internet. I think I have a reasonable idea of a workable plan together and would like to get some feedback/input from more experienced modders, especially those with some electronics know how.
I want to have both analog driver inputs (steering wheel + gas pedal) as well as digital RC inputs which will act "Daddy override" in the arduino who will be acting as the mediator.
The F150 I have is driven by 2 Fisher Price part 00968-9015 motors. From what I can find on the internet they are 12v DC brushed motors which others' tests show them to run @ 1.25amps with no load, and 70 amps during stall.
The motor controller I'm looking at is the Dual Motor Controller from ServoCity. In Dual mode Channel 1 acts in station keeping mode for a linear actuator with potentiometer based position sensor. https://www.servocity.com/actoboticsr-d ... -assembled
The Linear actuators available from ServoCity look like they would do the job nicely. I was thinking this one:https://www.servocity.com/hda4-2
Right now I have 2 SLA batteries hooked up in parallel and would prefer to keep it that way as long as it's still appropriate given the new electronics.
I have a foot pedal 1-20kohm variable resistor, and 20k potentiometer for the accelerator/steering wheel.
I haven't settles on RC parts yet, but they should be fairly simple to plug and play with the right setup otherwise.
Here's what I'm thinking:
By IWontPanic
#149027
Note that diagram shows the accelerator as a potentiometer, but it should actually just be a variable resistor, so I'll need to wire up a ~10kohm resistor and make a ohm-tester circuit to read it.
By Rob222
#149029
A potentiometer is a three-terminal resistor with a sliding or rotating contact that forms an adjustable voltage divider. If only two terminals are used, one end and the wiper, it acts as a variable resistor (Wikipedia).
