#149437
Need some advice. Picked up dodge dually and bypassed the little circuit board. However it barely moved. In reverse and low I have 12 volts to the motor. In high I have 4.2 to one motor and 4.8 to the other. I am not sure what else to be checking for that could cause it to bog down so bad. Pick rear end up and push petal and spins freely and fast. Could I have a bad motor or something similar? Any advice would be awesome
#149439
In high you should have 12v to each motor (parallel). In low or reverse you should have 12v supplied to both motors(series). Double check wiring. Sounds like you are getting the opposite results.
