#150724
Over winter the battery seemed unable to take a charge. The charger light never showed red, it just remained green for hours and never worked.
First, I bought and replaced the batteries but the green light symptom continued and doesn't charge.
Second, I purchased a new charger, but it does the same green light, no charge even for extended periods of time.
When I was installing the new batteries, I re-used the existing harness and checked the fuse and there was no indication of a blown fuse?
If you turn the quad on while plugged in the lights on the throttle will light up - but no lights or even "click" sounds when on battery.
Any ideas why the chargers would seemingly unable to charge the battery? Could a failed controller cause this?
New Here!
Peg Perego Magica parts
