By msgillett
#151114
We just purchased this sweet Bat mobile to rehab. Everything works but there is a short on the MB. A connection wiggles all car functions off and on. What is the best way to fix this?
#151117
That might be broken solder joints on the circuit board. Check the back side of the board and see if the solder joints at that plug are cracked or broken. If they are damaged, you would just need to re-flow solder (soldering iron or solder gun).
By msgillett
#151118
The back soldering looks good. The connection is tight. Could the inside connections be loose? Is there a way to fix then without replacing the connection housings?
#151129
A good cleaning of the connections wouldn't hurt anything. Some circuit board cleaner and a soft wire brush should remove any light corrosion. It's amazing how little it takes to disrupt a good connection. I like to use isopropyl alcohol to rinse off a circuit board after cleaning to remove left over residues.
Trailers
Peg Perego axle diameter
