#151244
LOOKING AT GOING BACK TO FACTORY BATTERIES CAN I USE THE WIRES FROM A CHARGER IN THE ACTUAL CAR?
Can I use the wires from a charger in the actual car?
I've been using aftermarket batteries but now a friend gave me her old batteries and charger. If I buy another charger can I use that to wire in the car so the battery will connect? Thanks for your help. It's been years since I have worked on the car.
#151245
Not sure which make or model you have but I would say no. The battery charge rate is much lower than the amp draw during use. The wires would have to be the same size/gauge and the wire insulation would need to have the same rating. It would be safer & cheaper to just buy a vehicle side plug off Ebay. Here's one for a 12v gray top power wheel battery for just under $12 delivered.
https://www.ebay.com/itm/Fisher-Price-1 ... SwoGtc8maU
Trailers
Peg Perego axle diameter
