#31560
Hi to all, I've done a conversion from a 12v to 18v of a PEG PEREGO ADVENTURE. I add a new 6v batteries to the 12v default battery with serial method. Used for this a old wire batteries and charger taken by an old 6v cars. I need of course to do an upgrade of the size of the cable, but I have another problem that I don't think could be caused by the size of the cable. In fact, after some seconds of used, and usually after a change of gear from the second gear to the reverse gear, the car stop working for few second. After some seconds it start without problem but the same occur after some seconds. Could be only the size of cable to do this ? Thanks in advance ...
#37123
I've bought both batteries in July 2011. Are both 7,2ah but one is 12v and the other is 6v. This is the image of the batteries of 6v.
I have to say that the 12v is used from my son on the car while I trying to do the conversion to 18v, so I think I recharged the battery for (more or less) thirty time. The 6v was recharged at maxium two time.
Thanks for your support ...
Roadside Jeep Limited rebuild
Well, a major finger injury took me out for a few […]
This drill: http://www.hitachipowertools.ca/en/Pro[…]
"Best" Choice JEEP
I'm not familiar with the brand but the symptoms p[…]
