By kie
#145642
Hi there,
I've just joined up. I've been modifying my sons ebike type quad for the last few years. I'm now working on his John Deere "power loader".
I've installed a 40amp speed controller with reverse and variable speed, he controls the speed with his right hand on the "dash" (wee-D uses a wheelchair). I'm running 12v but I've tested with 24v and it held together ! I've also fitted rubber tires I had knocking about.
https://www.youtube.com/edit?o=U&video_id=1q34QoT1gzg
I'm planning on hardening up the gearboxes... I'll try and document my work as I go, any tips to get me started ?
Cheers Kieran
It's normal to do that when raised in the air. If […]
Sweet ride! That sand was packed compared to the d[…]
motor upgrade on pw lil quad batman
I would like to upgrade the motor to 12v but I am […]
Newbie in the UK
Interesting. That looks like an older (red painted[…]
