By kie
#145642
Hi there,
I've just joined up. I've been modifying my sons ebike type quad for the last few years. I'm now working on his John Deere "power loader".
I've installed a 40amp speed controller with reverse and variable speed, he controls the speed with his right hand on the "dash" (wee-D uses a wheelchair). I'm running 12v but I've tested with 24v and it held together ! I've also fitted rubber tires I had knocking about.
https://www.youtube.com/edit?o=U&video_id=1q34QoT1gzg
I'm planning on hardening up the gearboxes... I'll try and document my work as I go, any tips to get me started ?
Cheers Kieran
Need wiring help
Any success?
John Deere Toy Gator HPX Help
I am new to this forum and unsure if this post is […]
Volts but no movement
Check battery voltages with pedal depressed. If vo[…]
Battery questions
1-Batteries are gone. Good rule for charging batte[…]
