By Jonnytop
#146689
Hi, thanks im a new owner of a 24v Gaucho, I have bought it secondhand, it's been stood up for a about a year but it was working fine now stopped works sometimes on and off!!!
Battery charged and holding charge
Any help please as my kids are very sad!!
Many thanks Jonny
By Rob222
#146690
More info please.
Is this an actual Gaucho SuperPower that came stock at 24V or a regular 12v Gaucho that has been upgraded to 24v ? If it is an actual 24V SuperPower then is it a first Generation version (bronze/orange) or the second generation black version ? If it is a SuperPower then what are the dash indicator (red/green) lights doing ?
Has the battery been sitting around for a year also ? Did it get charged periodically ? What kind of charger do you have and how are you charging the batteries ? Do you have a volt meter to check the voltage of the battery ?
"now stopped works sometimes on and off" - When does it stop working and how do you get it to go "on" again ?
By Jonnytop
#146691
Right then it's a 24v black model, the dash lights don't work, it second had so no idea of n the battery charging its holding 24.4 volts, some times I get a squeak ?
It's a plug to the mains
The throttle pedal is ona cable
Many thanks
By Jonnytop
#146692
It stops working after 1-2 seconds then goes doesn't work for anything from 1 to ten minutes or not at all
I lifted the rear end up and it worked once for 3 minutes
R/C Mustang for James
