#147099
Hi! names Dre. Always wanted to modify a power wheel and came across a 6v VW bus from a brand called RollPlay. Single motor on the right side and working headlamp LEDs. I stepped it up to 24v rear wheel dual Traxxas Titan 775 motors with headlamp, corner light and tail light 12v LED. Plastic tires have bicycle tire screwed onto them. Gas pedal acceleration modified onto horn button. It's really fun. Still trying to upgrade the gear box gears to metal but the plastic gears seems to be surviving...
#147103
i got one from rollplay too, i got the bmw i8
i got a 775 but it was to big so went with dual 550 traxxiss
but mines giving me issuies
she steps on it and it goes but lights been and when she lets go of pedal it wont go again.
will work if u unplug and plug back in
Custom Wheels question
newbie
Cruisin McQueen (nz)
