#147132
Hey guys/gals. My son is just over 1 and when I saw this opportunity I knew I had to grab it.
A "Powerwheel" popped up for free on the local market so I got it this morning. I knew I always wanted to rebuild or restore or modify a power wheel when my son got old enough.
Here it is, a Peg Perego Rzr 900
I don't know anything about it other than the guy said it needed a battery.
Regardless I'm looking forward into troubleshooting it and restoring it and upgrading it!
My plan is to take it apart, repaint it and look into the motor/battery options. For now I don't mind it being slow stock 12v since he's just one. I can upgrade later I suppose. It will definitely be getting some Emergency Lights since that's full time job.
I'm mechanically inclined (I've done real motor swaps and repair all my cars diy ) and electrically inclined so adding lights, relays and swapping out the motors is no problem. Just to give insight in my abilities.
Custom Wheels question
newbie
Cruisin McQueen (nz)
