By GJones
#149103
So its that time. I had a little girl that is getting big enough for a power wheels and since I had an original Bigfoot, she too must have one. So I have sourced a couple and just got them in the garage. I intend to build her a real nice 4wd one that looks pretty close to the original as far as stickers go anyway. So that's how I found my way here. I didn't have any idea that fixing these things up had any kind of following at all let alone a forum. Either way ill be looking for plenty of guidance from you guys on what motors I need to source for the 4wd conversion what I should or could do to beef the running gear up. Or any other suggestions for the rebirth of this Bigfoot. Looking forward to learning what you fellas have been up to. Glad this forum is around.
#149110
Welcome. There are a few posts on doing that very mod. Motors/gearboxes on all four wheels. Check em out and keep us posted.
Upgrading Gator
Relay parasitic drain?
