By Lrstara
#149506
Hello, first time using this so hope this works.
Just got a FREE raptor 660r. owner said the battery was dead. Found out the charger was bad. Got battery charged up and connected and nothing. Must have been a different battery because the red wire from the connector was on the negative post of the battery. Got that changed around still nothing. Checked continuity of the foot pedal, on/off switch and circuit breaker, all good. I see there is some type of "brain box" is there any way to check this out if it is bad? Could have changing the polarity of the battery burnt something up? I just assumed with DC the motors would have just run backwards. Any thoughts would be appreciated. I have worked on power wheels before and electrically they seem easier. Thanks for your help.
Body fastener/hold down
Hello. I recently found a gaucho rockin. Looking f[…]
Thanks for the reply! I ended up pulling the ye[…]
More torque
A Stage IV motor/gearbox kit has no durability iss[…]
Maybe a pore connection just enough to read voltag[…]
