By stu pidaso
#150104
Hey all,
I'm guilty of lurking for some time now, however I saw some excellent posts by Hammer-fm and decided it was time to contribute. This all started when I was given a pink barbie jeep - and since my 3 year old doesn't realize how much he likes pink yet, I repainted the car two tone OD green. Along the way now we've built ourselves a PWM controller, installed a variable speed pedal, tried various combinations of gears and motors and rebuild this little jeep entirely. We're running it on dual 18v li-ion battery banks, Nichibo KC3SFN-8021F/75's, 19 tooth pinions, and repurposed oem gas pedal for brake only. We've successfully worn almost completely through these hard plastic tires - but the boy is speed hungry and loves to drift so there you go. Working on traction control circuit and regen circuit as well as implementing a wifi kill switch. Nice to make all your acquaintance and thank you all who have posted - you have saved me untold hours of energy.
Steering linkage since been rebuilt.
ride on jeep mod.png (407.78 KiB) Viewed 312 times
#150463
Great to have you on board! Nice work on the Jeep, enjoy these years, they pass fast!
newbie with wheels
pictures
Would it be possible to use this switch in the ste[…]
Keep the supply voltage to the relays and accessor[…]
