#140400
#140433
Nice!
#140462
Suburbancharlie77 wrote:Can't imagine how that would go if nightmares driver had a better response time! Pulled through and finished the competition.
I think I must have missed the part of the build with the push button wastegate parts? Have you got a compressor onboard?
its not boost but a nos purge valve and its just a bottle of compressed air in nitemare. The red vette is the one with the electric twin turbos and it is just a speaker that makes a blow off sound.
Actually nitemare is a dog off the line as I have mentioned in the build thread. Not exactly sure if it is the motor, batteries, esc, or the winch solenoids that is bottle necking the amps. He pushes the pedal but it takes a while to get going. I am going to swap out the contactors for a ev setup after i get some dyno pulls with this setup.
Circuit breaker popping
Ok so tried a fuse then the circuit breaker starte[…]
