By fast five
#48886
Brand Ride: Per Perego
Model: Gaucho Rock'In
Code: IGOD0047
Other: Brought brand new at SGD$1300++
Battery Charger: Ctek Model MXS 5.0 at SGD$175
Mod Done:
1 - 12V 33ah - Model: TLA12330 - Brand: UNICELL - Weight: 5.5 kg with 30 amp fuse at SGD$106
2 - 12V 20ah - Model: DLA12200 - Brand: UNICELL - Weight: 3.5 kg with 30 amp fuse at SGD$63
= Total 53ah inside the power ride boot.
2 - Ctek battery indicator - Model "COMFORT INDICATOR PANEL" at SGD$30
*Feedback on Ride Duration with Battery in Full Charge
Number of Outing: 3 times
Duration of Each Outing: Estimated 1hr 15mins
Number of Pax in the Ride on each outing: 2pax
Estimated weight: Base on two pax is 47kg or 55kg
Riding Surface: 70% Short Grass (Cow Grass) and 30% Hard Concrete
Balance Battery Level after 3 outing: 50% (as shown in the Ctek battery indicator)
Riding Speed: 60% Low Speed / 40% High Speed
Remark:
- Battery connector get warm while travelling with high speed for around 30mins with 2 kids of 55kgs and the gear box thermal fuse breaker start to kick in then ride will be moving on and off.
- But if travelling for whole hour with 47 kg in low speed no issue at all.
- There are some gear slipping off because the two kids of 55kg had move the ride in high speed and most of the time with very frequent stop & go on the gas pedal.
12V Gaucho Rock'In - Front View
12V Gaucho Rock'In - Front View.JPG (61.45 KiB) Viewed 1491 times
12V Gaucho Rock'In - Side View
12V Gaucho Rock'In - Side View.JPG (116.81 KiB) Viewed 1491 times
12V - 20Ah & 33Ah Battery Location in the Boot
12V - 20Ah & 33Ah Battery Location in the Boot.JPG (64.85 KiB) Viewed 1491 times
UNICELL Battery - 12V 20Ah
UNICELL Battery - 12V 20Ah.JPG (93.83 KiB) Viewed 1491 times
UNICELL Battery - 12V 33Ah
UNICELL Battery - 12V 33 Ah.JPG (67.63 KiB) Viewed 1491 times
Ctek Battery Indicator
Ctek Battery Indicator.JPG (109.97 KiB) Viewed 1491 times
Children with the New Ride
CHILDREN WITH THE NEW RIDE.JPG (50.15 KiB) Viewed 1491 times
Batmobile- 1992 Power Drivers
Plasti-dip
