By 87jeepwrangler
#117905
last month a friend's Gator HPX took a little hit. amazingly, the front and rear axle, wiring harness, seats, and battery remained unharmed. needless to say, it was no longer of any value to them, so i scooped it up.
photo 3.JPG (57.33 KiB) Viewed 2364 times
my original plan was to throw the parts under a jeep PW body i had laying around, but once i saw the body on there to get a look, i quickly realized the front and rear tires are different sizes. yuck. to me, a jeep shouldn't have different size wheels.
photo 1.JPG (43.24 KiB) Viewed 2364 times
disappointed, i walked away to give it some more thought. when i came back, my kid had been playing with it, and accidentally knocked it over a little bit, as seen in the picture below...
photo 2.JPG (47.13 KiB) Viewed 2364 times
still not in love with the idea of the jeep having different size wheels, it at least crossed my mind to make it into a drag car looking jeep, although i'm far from sold on the idea.
or, i could weld up a quick flat frame for the axles and seats, but i don't really know where id want to go from there.
you guys have any ideas? i've got a lot of other projects going on right now, so i'm hoping to keep this one somewhat quick and simple. what would you do with the parts? all ideas welcome.
By hkayssi
#117919
Or just buy another used set of tires to make the tire size the same on both axles :D
You can sell the parts you'll have left to offset the cost of acquiring the tires too :D
That is the classic Gator not the HPX though :)
#117921
OUCH!
I can relate to the snow crushed power wheels thing :(
By hkayssi
#117937
87jeepwrangler wrote:I like the get new matching wheels idea.
So it's definitely not a hpx? Excuse my ignorance, how can you tell, and is that good or bad? How hard will it be to find two more larger wheels?
Definitely not an HPx. Here's a pic of the HPX, look at the tire thread, the hub caps, the front grille and lights as well as the battery cover on the front That is a good thing parts are more readily available and cheaper :)
By hkayssi
#119174
If you decide part out the Gator, will you please let me know?
I need a few parts. I need the windshield the bed hydraulic cylinder release with the red pull on strap & the lock on the dash with or without the key
By 87jeepwrangler
#121115
update!!!
i threw these parts upstairs and sat on them until i recently found a place to put them. i came across a peg perego pedal powered construction hauler that was pretty rough around the edges. it was missing the bucket, and essentially just looked like a tractor. the steering was sloppy and the tires were about to wear through. i decided the gator axles might be a good fit under the pedal powered tractor, but its turning into more work than i had originally hoped. o well. on to the pics...
here's what the pedal power tractor looked like new...
the pedal powered front steering axle next to the gator steering axle. huge difference in size and scale.
photo 1.JPG (37.99 KiB) Viewed 2151 times
the axle needed narrowing to make it look like it fit. i decided to remove 4.5" from the axle.
photo 2.JPG (38.05 KiB) Viewed 2151 times
By 87jeepwrangler
#121117
the start of the steel bracket to connect the gator axle to the tractor
photo 3.JPG (45.45 KiB) Viewed 2150 times
i used the original steering axle "kingpin" pieces to connect the new axle to the original mounting location.
photo 4.JPG (46.21 KiB) Viewed 2150 times
the new narrowed gator axle connected to the steel bracket.
photo 5.JPG (40.25 KiB) Viewed 2150 times
another view
photo 6.JPG (40.21 KiB) Viewed 2150 times
here is the whole assembly mounted
photo 7.JPG (38.96 KiB) Viewed 2150 times
By 87jeepwrangler
#121118
new tie rod and steering mechanism
photo 8.JPG (42.11 KiB) Viewed 2148 times
the old gator tie rod was a stout plastic piece, but was now 4.5" too long, and had offset steering (the tractor has the steering wheel centered), so it just wasnt going to work. to connect the new tie rod to the knuckle, i machine 2 delrin spacers on the lathe that fit inside the knuckle and gave me a 3/8" hole instead of a .840" hole.
photo 9.JPG (46.06 KiB) Viewed 2148 times
inserts in place in the knuckle.
photo 10.JPG (33.33 KiB) Viewed 2148 times
completed steering assembly on the axle.
photo 11.JPG (54.96 KiB) Viewed 2148 times
By 87jeepwrangler
#121119
i also remade the steering column, but forgot to take a picture of that. here's the entire front axle assembly finished and mounted (minus paint), and the rear tires just sitting under for the photo op.
photo 12.JPG (46.1 KiB) Viewed 2148 times
here's the wiring harness i was able to salvage from the original wrecked gator. does anyone know or have a wiring diagram for this thing? not sure which wires go where. the shift lever has a reverse, high and low speed. is my fuse block missing any fuses or other parts?
photo 13.JPG (45.63 KiB) Viewed 2148 times
#121127
:D :D :D That's coming out pretty darn cool!
