Ferrari F1 Aluminum Frame with 2 x 1000W steel gearbox build
Posted: Fri Oct 09, 2015 11:15 am
by Gwagon
I have been discussing this build in the general discussion section and have decided to continue it here. viewtopic.php?f=3&t=18749
I have a Berchet F1 and plan to build a new aluminum frame to handle more powerful motors.
Here is what I have so far in sketchup. The planned improvements are a more rigid frame with battery trays on the side of the driver, adjustable front camber and the ability to mount go kart slicks. I ordered some used Bridgestone slicks that will fit perfectly.
aluminum frame design in progress
Berchet F1 frame v7.jpg (434.1 KiB) Viewed 9910 times
4.5 x 10.5 fronts and 7.1 x 11.5 rears
bridgestone slicks.jpg (263.82 KiB) Viewed 9910 times
I have questions on drivetrain options. Per Toycrusher's suggestion, I ordered 2 1000W scooter motors with gearboxes. I think I have 4 ways to build the drivetrain.
scooter motor with gearbox
1000W direct drive motor.png (206 KiB) Viewed 9910 times
1. single direct wheel drive
single wheel driver.jpg (374.24 KiB) Viewed 9910 times
2. dual direct wheel drive
dual wheel drivers.jpg (430.89 KiB) Viewed 9910 times
3. single with quasi live axle
quasi live axle.jpg (390.98 KiB) Viewed 9910 times
4. dual with quasi live axle
dual connected.jpg (459.46 KiB) Viewed 9910 times
I need some help on which way is the best way to drive this project. I read through all of the dual motor and live axle setup threads but still cannot find an answer. The dual direct drive looks interesting but what if the motor running in reverse is slightly running slower than the other side? Would that be a problem? The connected live axle might cause some issues turning on asphalt. I hope the experts can help point me in the right direction.
Re: Berchet F1 pole position build
Posted: Fri Oct 09, 2015 12:34 pm
by toycrusher
Personally, solid axle not worth the handling issues. I wouldn't worry about the difference in power between the two sides, the traction of the tires will more than overcome any slight power differential ;)
Posted: Fri Oct 09, 2015 8:52 pm
by Gwagon
toycrusher wrote:Personally, solid axle not worth the handling issues. I wouldn't worry about the difference in power between the two sides, the traction of the tires will more than overcome any slight power differential ;)
That sounds good TC.
The motor company is customizing the rotors for me to change the motors from 390RPM to 450RPM at 36V. The speed calculator says using 11" rear tires at 450rpm will yield 15MPH.
Each motor will provide 20.0N.m of torque. What are the pros and cons for using 1 vs 2 motors? Do I need more torque or more run time? The need to carry more batteries for the second motor is also a consideration.
Posted: Fri Oct 09, 2015 10:11 pm
by toycrusher
For a solid axle you could use one motor but independent you definitely need two or one will spin out on take off or corners
Posted: Mon Oct 12, 2015 10:43 am
by Shurik2001
Gwagon, Judging by your setup it will be an amazing build. I’m very envious of your project.
In my humble opinion this car can safely go faster than 15 mph and I would use chain drive to easily control max speed and torque.
I have some experience with the above DC motors as I was modding electric scooters for a few years now. And again IMHO you need a decent H-Bridge ESC or a 60+ amp relay for reversing. Relay is probably a cheaper option as high current H-Bridge ESCs tend to be expensive. One way or the other you need an ESC with strong protection against overcurrent and some additional circuitry to enforce a stop cycle when reversing (much like a real car does it).
Changing motor direction even at low speed without going thru a stop cycle first generates tremendous currents that can easily destroy most cheap Chinese scooter controllers and burn out motor brushes. A damaged controller can unleash full battery power directly to the motor(s) rendering a car uncontrollable (been there, done that).
I recommend installing an easily accessible circuit breaker (40 amp Blue Sea Single Pole Magnetic Circuit Breaker) and train your kid to use it if something is wrong. I use one as a main power switch and it is very convenient. Also I would build a simple circuit to automatically shut off power when accelerator pedal is not pressed and any of the motors is powered on.
Anyways best of luck with your build.
I’m looking forward for your project completion
Posted: Tue Oct 13, 2015 9:17 pm
by Gwagon
Thanks for the tips guys. I already ordered the motors with gearboxes so hopefully they will work well. I was checking out Jonesee's RZR and it was running at over 20MPH on 24V. If I can achieve that on this car running on standard voltage, I will be a happy camper. When I use a speed calculator I only get 15MPH though.
I will look into the relay for reversing and the circuit breaker. I am thinking about using Kelly Controllers as they are programmable. Good to know about the stop cycle. I will have many more questions about electronics when I get into it. The aluminum came so I will start cutting when I have some time. Thanks for the support.
Posted: Wed Oct 14, 2015 1:54 am
by toycrusher
The difference in speed is due to the tire diameter. As far as relays, duty cycle is an important criteria. Do a search for another Jonesee project "nitemare". In that one it took a couple tries to find appropriate relays for the high amperage motor
Posted: Wed Oct 14, 2015 8:47 am
by Shurik2001
I just ordered couple of 24V 80A relays for my next project. I'm pretty sure they will do:
http://www.amazon.com/gp/product/B0097B ... ge_o01_s00
Posted: Thu Oct 15, 2015 11:13 am
by Gwagon
I just read the Nightmare build and it blew my mind. What an awesome project. I will look further into the relays later. For now I have been reworking the design on Sketchup. The frame will have adjustable camber for the front spindles. I have been trying to come up with the best way to mount the direct drive gear box motors. I am going to order some 3/4" motor shafts, get them drilled and welded to the smaller 15mm shaft. I need to find someone with a lathe to help me drill a 15mm hole. In the image you can see how the motors will be mounted and also the outriggers to support the extra long shaft and wide wheels. What do you guys think?
working out the motor mounts and shaft support
Berchet F1 frame v12.jpg (271.65 KiB) Viewed 9799 times
The Bridgestone tires are too small so I am ordering some Maxxis tires that match the original tire sizes a little better.
I have been looking at the Kelly controllers. Should I be looking at regen braking for the rear if I plan on front disc brakes? How many amps should I be looking at? for the controllers I will be running the motors at 36V first and then possibly 48V. Would 48V kill the motors? Running at 20mph would be ideal.
Posted: Thu Oct 15, 2015 12:13 pm
by Shurik2001
I would go with two of these: http://kellycontroller.com/kds48100e100 ... p-285.html
With 100 amp at @ 36v you will get some serious torque and impressive burnout on a toy car! 48 volts would not kill these motors but I think it is an overkill. I use a similar motor on a standup scooter and @ 60 amp 36v I can do a willie. 36v LiPO or LiON should be more than enough.
I prefer to build motor controllers myself and thus have no experience with Kellies. I do not know how they would behave if you reverse motor polarity at full speed. Judging by the Kelly’s wiring diagram the controller is unaware of a forward/reverse switch state.
Even if their controller survives the overcurrent, the mechanical stress from the suddenly stalled motor would be considerable.
Like I said in my builds I go thru a stop cycle but I am not an expert.
It would probably be a good idea to post a question on https://endless-sphere.com/forums/ as they seem to be more experienced in power setups like yours.
Posted: Fri Oct 16, 2015 9:11 am
by toycrusher
There's a pretty easy workaround to avoid shifting fwd/rev while in motion. Using this diagram, you basically create a "brake lock-out" feature that prevents the ride from being shifted into reverse unless the brake pedal is being pushed. Once it's shifted into reverse the brake can be released. See if this diagram makes sense.
Stop to shift jpg.jpg (74.25 KiB) Viewed 9782 times
Posted: Fri Oct 16, 2015 1:19 pm
by Shurik2001
Here is a simple and elegant flip-flop based solution that will do the trick.
Stop Enforcer.jpg (109.12 KiB) Viewed 9773 times
As long as the motor is rotating in any direction relay K2 keeps the “reverse” switch circuit open. A flop-flop trigger made of a 2 NAND gates (4011) continues to maintains its state. As soon as the motor stops K2 reconnects the “reverse” switch which can now change the state of the flip-flop trigger that controls motor polarity relay.
This circuit will allow direction switching only when motor is idle or almost idle depending on the release voltage of K2 relay.
Posted: Fri Oct 16, 2015 1:36 pm
by toycrusher
Shurik2001 wrote:Here is a simple and elegant flip-flop based solution that will do the trick.
:shock:
Yeah, I'm not familiar with most of those symbols. Do those components go on a printed circuit board?
Posted: Fri Oct 16, 2015 2:01 pm
by Shurik2001
Yes, PCB is an natural choice for these but you can wire them without any PCB. I prefer perforated boards (http://www.instructables.com/id/How-to- ... rcuit-Boa/) even for much more complex projects.
Flip-flops are the basis of all modern digital electronics. https://en.wikipedia.org/wiki/Flip-flop ... tronics%29
If you have time you may want to build this thing just for the fun of it.
Posted: Sat Oct 17, 2015 6:45 am
by toycrusher
So they are basically giant sized versions of what's inside a typical ic chip?
Posted: Tue Oct 20, 2015 12:30 pm
by Shurik2001
My appologies if i seem to hijack this thread.
Enforcing motor stop prior to direction change can be done usuing relays. Just replace the IC with couple of relays and you are good to go:
http://relaysbc.sourceforge.net/circuits.html
Posted: Fri Oct 30, 2015 10:56 am
by Gwagon
Here is an update on this build.
Parts and materials are rolling in. I just receive the motors but mounting tabs were broken off during shipping. I hope the factory will get me replacements soon. I signed up for a TIG welding class and bought a TIG machine so I can do my own welding. My employee bought a MIG for a work project but I was not too happy with the quality of MIG welds. I want to have clean welds that they do not need to be ground down afterwards. I hope to be able to make clean welds without too much trouble. Tires, wheels, rotors, calipers, bearings and hubs arrived. Time to start cutting as soon as my cold cut saw arrives. I worked on the design some more. The front arms have more support now.
Berchet F1 frame v26.jpg (418.91 KiB) Viewed 9647 times
I first started with tires for 5" wheels but now will use 6" wheels. The front tires will be 6"wide 11" in diameter
front go kart tires
front tire choices.jpg (278.16 KiB) Viewed 9647 times
The rear tires will be 9" wide by 12" in diameter. I am not sure if the massive grip of 9" wide tires will be too much traction or drag. What do you guys think?
rear go kart tire next to original plastic wheel
rear tire.jpg (293.46 KiB) Viewed 9647 times
I don't trust the plastic wheel so I am changing it to an aluminum wheel. I will be adapting front go-kart brakes.
aluminum wheel and rotor
aluminum steering wheel and rotor.jpg (307.77 KiB) Viewed 9647 times
the metal gears are pretty beefy. Does the grease look synthetic to you? It looks similar to my mobile one synthetic grease.
a peek into the metal gearbox
gearbox insides.jpg (235.75 KiB) Viewed 9647 times
Posted: Fri Oct 30, 2015 2:37 pm
by toycrusher
You just can't leave things alone can you? Gotta open it up and what's inside... :lol: :lol: :lol:
Posted: Mon Nov 02, 2015 3:40 pm
by Gwagon
I couldn't help myself. : )
Posted: Fri Nov 06, 2015 12:47 am
by Gwagon
I did not plan to get so deep into this build but reading all of the cool projects here inspired me to make this ride on a cool one. You guys rock and I am learning so much from the posts.
My shop is setup for woodworking so I need to get some metal working tools.
I am taking my TIG class next week so I can learn to make clean welds in aluminum. I hope the learning curve is not too steep. Here are some tools I received already. Will be cutting material soon. : )
Putting together a TIG setup
Miller DIversion 180.jpg (306.82 KiB) Viewed 9581 times
Makita metal saw
Cold Cutting saw.jpg (302.47 KiB) Viewed 9581 times
Posted: Fri Nov 06, 2015 10:58 am
by toycrusher
"For those about to rock... We Salute You! 8-) 8-) 8-) :lol:
Posted: Tue Nov 10, 2015 1:07 pm
by Gwagon
brake rotor mount
The hubs came with threaded holes for 1/4" and 5/16" bolts. I used the extra holes to connect the two hubs and also to mount the rotors.
Final checking of the mounting position before I start drilling and cutting.
FIne tuning in a mock up beam before drilling holes for the tubes.
rotobroach in action
I used Rotobroach Cutters for the first time and they cut beautifully and accurately. I couldn't trust my standard hole cutters to get a precise fit.
it fits!
The tubes fit snugly into the holes. I was worried about alignment so I took my time setting up. I am still waiting for a 24mm cutter to drill a hole for the bearing to hold the short end of the shaft.
moment of truth
The shell fits the newly cut chassis. This is going to be a strong frame. I hope it is not going to be too heavy. It has been a game of strengthening and lightening. It has been a tug of war when I am designing in sketchup.
support beams for the tub
I am thinking about an X brace right under the rum area. I noticed a few cracks forming right around the seat area. I will do some ABS repair with Weld On and plan to support the stress points better to prevent future cracks.
I will be taking my first TIG welding class this Friday.
Posted: Sun Nov 15, 2015 6:53 pm
by Gwagon
Here are some scraps I welded in class. They don't look too pretty. I just need to practice now at home and get my skills up to speed before I weld the frame. Tig welding is pretty fun actually.
Tig Welding intro class
It would be nice if I can make hub centric rings for the rotors. This F1 car will stop very quickly with these rotors.
These rotors fit the hub bolt pattern better
Re: Ferrari F1 Aluminum Frame with 2 x 1000W steel gearbox build
Posted: Mon Oct 09, 2017 12:18 am
by Gwagon
It's been almost a 2 year hiatus but I'm back on this project. My son is now 19 months so I expect him to be ready for this car when he is around 2.5-3 years old. I am almost done with his Lamborghini in the background.
The motor mounting plates and front arms are now designed and the 3D printed prototypes are being test fitted. We will have the designs sent out to get the aluminum parts cut out using a water jet hopefully this week. The guys at work helping out are pretty excited about this project. I am increasing the track of the car to about 38" which is close to ideal for the 47" wheelbase.
Wesley suggests me to get a 4QD controller so I'll be ordering that soon. I am also looking at using lifepo4 batteries. I can fit a 48V 28ah pack right behind the driver.
Stay tuned. More to come soon.
F1 and Lambo in shop.jpg (612.44 KiB) Viewed 7911 times
F1 motor mounts 3D printed.jpg (610.29 KiB) Viewed 7911 times
F1 front spindle and rotor on 3D arm.jpg (640.42 KiB) Viewed 7911 times
Re: Ferrari F1 Aluminum Frame with 2 x 2000W steel gearbox build
Posted: Mon Oct 09, 2017 7:02 am
by toycrusher
Hey! Welcome back!!! :D
Has it seriously been two years? :shock: Time flies! Can't wait to see more 8-)
Posted: Mon Oct 09, 2017 8:56 am
by Gwagon
Thanks Toycrusher. Time does fly especially for me after my first child who was born 19 months ago. The time off gave me some time to refine the front arm and motor mount designs.
Posted: Tue Oct 17, 2017 9:29 pm
by Gwagon
The project is picking up pace.
The 1" tubes have been turned, keyed, and welded to the gearbox shaft. We mounted it on the frame with the 3D printed plates and fired it up using 38V. There is a small vibration but it should be livable. The hubs can be adjusted so the track can be 36-38.5" wide. The part files have been sent to the water jet company. I can't wait to see all of the aluminum parts cut out.
[/url]
Posted: Thu Nov 30, 2017 5:00 am
by Gwagon
Here are some updates.
The water jet cut parts are here.
The parts fit
The hub centric rings for the rotors are being cut and then installed
The lifepo4 battery and the 4QD controller are here
After I drill the spindle holes, we should be ready to start tig welding the chassis together.
Posted: Fri Dec 01, 2017 3:23 am
by Gwagon
It's coming together.
The front beam has been drill and tapped for the spindles.
The motors are attached to the inner motor plates.
Posted: Sat Dec 02, 2017 2:24 am
by Hammer-fm
Looking good -- really like watching this one come together!
Posted: Wed Dec 06, 2017 2:47 am
by Gwagon
Thanks Hammer. It's been a fun project so far.
Here is a pic of the rear motor and wheel being test fitted. I hope the inner and outer aluminum bearing support plates will be strong enough to hold the axles without deflecting. Using the laser cutter to prototype the parts in hard board helped get all of the dimensions and holes in the right places. Without the laser, I'm not sure how I would do so before the water jet stage. Time to weld the ladder frame together next.
Posted: Mon Dec 10, 2018 6:37 pm
by Jasonownsansw20
I love the F1 body, and love all the fabrication work that has been done on this, I'm just wondering if you considered adding any type of suspension to your setup? If it was me I wouldn't be able to help myself esp for an F1 build, also love the wee lamborghini, where did you buy your car body's from originally?
Posted: Mon Dec 17, 2018 8:54 am
by Gwagon
I have thought about suspension for the F1 but it would take a bit more time to work it in to my tight schedule. I have been really busy at work and just got back into this project a couple weeks ago. I am now on designing the mounting for the steering column to fit a larger steering wheel. After that I will work on the brakes and the speed controller. The F1 was a lucky find on EBay. Someone locally was selling it so I grabbed it right before my son was born. He will be tall enough soon so I better put some time into it now to wrap it up in the next few months to make it in time for his third birthday. He is still getting the hang of the Lambo so the F1 will be too much for him to handle. I’ll be posting more after the holidays. Happy Holidays to All.
Posted: Mon Dec 24, 2018 2:00 pm
by toycrusher
Gwagon wrote: Mon Dec 17, 2018 8:54 am I have thought about suspension for the F1 but it would take a bit more time to work it in to my tight schedule. I have been really busy at work and just got back into this project a couple weeks ago. I am now on designing the mounting for the steering column to fit a larger steering wheel. After that I will work on the brakes and the speed controller. The F1 was a lucky find on EBay. Someone locally was selling it so I grabbed it right before my son was born. He will be tall enough soon so I better put some time into it now to wrap it up in the next few months to make it in time for his third birthday. He is still getting the hang of the Lambo so the F1 will be too much for him to handle. I’ll be posting more after the holidays. Happy Holidays to All.
Keep the updates flowing! 8-)
Posted: Wed Jan 09, 2019 7:09 am
by Nurburgringer
awesome thread, looking forward to more updates!
Where did you source the steering wheel?
Posted: Fri Jan 11, 2019 9:49 am
by Gwagon
I Worked on a few things recently. I am designing the mounting supports for the steering column. The challenge is to still be able to remove the plastic shells afterwards. After the front end is completed, it will be the battery and speed controller mounting and wiring.
I modified a larger steering wheel to fit.
The wheel is mounted on a quick release hub.
The rotors had new mounting holes drilled to fit the hubs. Aluminum height spacers were added to maintain consistency.
Posted: Tue Jan 15, 2019 9:53 pm
by Gwagon
I found a Hall effect pedal that fits pretty well after lopping off a couple of inches off the top and drilling the mounting holes. It was hard finding a pedal that fits the shell compartment and sits at a good driving angle.
Posted: Thu Feb 28, 2019 12:44 am
by Gwagon
Here are a couple of quick updates on the project. I had a problem with the hall effect pedal talking to the 4QD controller for a few weeks. Tech support at 4QD help me figure it out and it now works. The Anderson Powerpole connectors started to melt from the 48V battery sparking when connecting to the controller. I replaced them with XT90S anti spark connectors and the sparking is now gone and they fit 10 gauge wire nicely. The old Bridgestone tires were too old and didn't hold air so I bought some new Vega tires and had them mounted. I am about to fabricate the steering column supports and design the battery and electronics tray. The shafts for the gear boxes have a slight wobble to them from the welding of the 1" tubes to the shafts. I have just redesigned the shaft with the 1" extension in 3D and will be turned on the cnc lathe.
Posted: Wed May 15, 2019 8:13 am
by toycrusher
Gwagon wrote: Thu Feb 28, 2019 12:44 am Here are a couple of quick updates on the project. I had a problem with the hall effect pedal talking to the 4QD controller for a few weeks. Tech support at 4QD help me figure it out and it now works. The Anderson Powerpole connectors started to melt from the 48V battery sparking when connecting to the controller. I replaced them with XT90S anti spark connectors and the sparking is now gone and they fit 10 gauge wire nicely. The old Bridgestone tires were too old and didn't hold air so I bought some new Vega tires and had them mounted. I am about to fabricate the steering column supports and design the battery and electronics tray. The shafts for the gear boxes have a slight wobble to them from the welding of the 1" tubes to the shafts. I have just redesigned the shaft with the 1" extension in 3D and will be turned on the cnc lathe.
Any updates since February?
Posted: Sat Jun 01, 2019 1:03 pm
by Gwagon
I made some new parts. The welded pipe over the shaft had a slight wobble so I decided to model it in 3D and CNC lathe the whole shaft. Measuring and remeasuring took some time but it fit the gearbox well.
CNC version
It fits
it fits
I wanted to have steering support that will still allow the plastic shells to be removable. Two needle bearing blocks hold the shaft.
Steering shaft support
Needle bearings
Here I’m making the battery and 4QD trays. I want to keep the weight distribution closer to the front so it is up on its side. The body had to be trimmed to fit the battery. I trimmed the rear tray at an angle.
Trays
Shell trimmed
Shaped the rear tray
I’m going to need to get some tig welding help as the steering support has 1” thick pieces and my welding machine is too wimpy. I just ordered tie rods and ends for the steering. I hope to get it completed soon.
Posted: Tue Jul 09, 2019 11:46 am
by toycrusher
This is really an insane build 8-) 8-) 8-)
Posted: Tue Jul 09, 2019 5:44 pm
by wired
Agreed. Top notch.
