By Coopz
#137689
had been on the look out for a lightning mcqueen for ages,one come up on ebay and fate has it,he was mine. It was in pretty good nic,hadnt been used much.18v straight up and my young bloke was happy,but I wasnt lol as this is lightning mcqueen so this car needs to be modified.
mocking up with go kart wheels
go kart wheels and a kickass controller was on the cards
shortened the front axle and put a thread on the end
spacer
shaved down a spacer to 17mm to fit in the bearing case.
spacer fits nicely into wheel bearing
battery holder
will be placing the batteries 2 x 12v 15ah or 12v 22ah plenty of room there, the low centre of gravity and balances ride. probably will end up putting another battery under the hood for a 36v upgrade.
battery holder
bit of a mission to find secondhand 25mm rear hubs so end up buying new ones.25mm pillow block bearings and 25mm sprocket carrier. another mission was looking for a 25mm axle, Opting to 25mm aluminium tube .
rear axle
rear axle
rear axle
By Coopz
#137690
side view
Started working on the rear frame.bit of trial and error in this department,will see how much strenghtening is needed in this design as i will end up making up a aluminium frame.
rear view motor frame
under view motor frame
installed a 48v 1000w unit motor.
motor install
motor side view
put it back together to see how it looks, just over the halfway mark to finish Lightning.
My young bloke sunny is looking forward to testing this car out.
checking the body fits back together
#137693
Best looking Mcqueen I've seen. Please keep us posted on the progress.
#137696
Doing it right!
You should seriously consider building in a roll bar loop into the frame. Even through the cars CG is low, the kid driving it has a high CG, sticky rubber, short wheelbase, TONS OF POWER = very high rollover risk. With your skills it wouldn't take much to do something like this
By Coopz
#138461
Back on the Lightning McQueen, oh how I've missed working on this one.
Installing the speed controller
Motion dynamics 50amp speed controller
#141555
What's the reason for the overhaul?
#141847
That's so much fun it should be illegal! :P Really good to see him wearing a helmet, safety first cause kids are a hassle to replace :shock: :? Ok bad joke. Good to see you setting the example! :D
By Coopz
#141875
This car has to be my favourite build and Sunny's to by the looks of it. No helmet, no ride policy with these cars that are beyond the 12v range in our household.also if any kid breaks the rules there license gets suspended for the weekend.happens from time to time on serious breaches like crossing the road with out being told to etc etc. @toycrusher
By Coopz
#142066
No mechanical brake just the regen brake in the controller,back off the gas pedal and it kicks in. Simple and very effective.these are the controllers I use,Australian made.
https://www.motiondynamics.com.au/12v-3 ... model.html
By redline
#142199
Coopz wrote:pretty sure it was B @redline,i only hook up the reverse switch and bridge the on/off switch as i run a isolater on the positive line from the battery to the controller.
Ahh nice ... you run just the single motor right? It should run dual motors ok though?
By Kombicol
#142337
First of all, really neat build. Love it.
So, interested in these controllers you are using also.
Looks like a neat way to eliminate a lot of the relays used with the standard ESC method folks are applying.
Do you need one of those special golf cart accelerator pedals that provide a SPST contact on release of the accelerator, or is all this done from inside the controller based on the hall sensor input (or lack thereof).
For applications with multiple motors have you tried to run series for reverse and low speed or do you run a single speed for all gears?
By Coopz
#142349
the controller can be used with twist throttles or foot pedals,yes they are simple for wiring and the regen braking eleminatesa second pedal.reverse function is simple as well but the speed can not be adjusted.ive tryed putting a pentimeter on the control line of the pedal but it didnt do anything.why? i'm not sure. dual motors is a easy set up using the controller.check out the video on motion dynmaics page it has the run down on the controller.
By Gunda72
#147609
HI there Coopz.
I'm from Italy so..forgive my english please.
I'm in the midlle of the power transformation of the mc queen of my sons and your thread is great.
I've a question about the sprocket and the crown.
How many tooth ?
Thx a lot!
Daniele.
bad charger ?
Huffy Lightning Mcqueen
Kids motorz Chevy bel air
Help please
