By edac
#139497
So I finally put Wesley's kit in.
Used cut up milk jug to make the 7/8" controls fit on the 3/4" handle bars
phone 137.jpg (21.31 KiB) Viewed 1156 times
phone 138.jpg (40 KiB) Viewed 1156 times
cut rear of body so I could tuck two batteries above the back axle.
phone 141.jpg (33.19 KiB) Viewed 1156 times
sportsman2x 013.jpg (45.98 KiB) Viewed 1156 times
Cut up and bent some scrap sheet metal to hold controls, and wired.
sportsman2x 008.jpg (52.19 KiB) Viewed 1156 times
After a few issues pulled the 100 ohm resister out of the 12vdc coil circuit and checked operation, Okay!
sportsman2x 010.jpg (56.48 KiB) Viewed 1156 times
sportsman2x 012.jpg (39.9 KiB) Viewed 1156 times
sportsman2x 014.jpg (50.76 KiB) Viewed 1156 times
Still need to get a lens and the Eagle eye LED's working.
#139528
Love your mounting solution. I really struggled with mine trying to install and wire the electronics up under the "gas tank". Great ideas you had here!
By edac
#139540
Just ordered 4 12v12ah Gruber batteries for this, should give the girls hours of run time.
