By TR7man
#145762
My name is Shane, and I bought my son, Mason, who is 2, an ActionWheels 6v Batmobile for Christmas 2016. Here is a pic from WalMart:
I didn't recognize this batmobile model, until I started playing Arkham Asylum:
There is a HotWheels toy:
And TheBrickBuilder14 created a really cool custom Lego model:
I mentioned this project in this post: viewtopic.php?p=144168#p144168
With only 6 volts, it's speed was very slow, at 2.5mph, measured using a speedometer app on my phone. I've upgraded it with a 2nd 6v motor/gearbox, wired backwards, in parallel, purchased from Ballard Pacific.
Running it with a single 6v battery, it ran at the same speed, it seemed to drive better in the grass, but had a very shortened run time.
Adding a 2nd 6v battery in series, doubled the speed, but still had a shortened run time.
My plan is to add 2 x 12v batteries, in parallel, for double the speed, and normal run time.
I'll post pics of the modifications I had to do to the axle, to accommodate the 2nd gearbox/motor, and the custom wire harness I built.
By TR7man
#148084
I've added a 12V/12AH battery, purchased from Ballard Pacific, and it runs about 4.2 mph, slower than a 12v PowerWheels, but sufficient for my 3 year old son.
Before I replace the motors with 12V ones, I've decided to add 2 Nerf Stryfe Blasters, like this, Image, but painted black, with a barrel extensionImage, and the handgrip cut off. I've already purchased the 18 dart clipsImage, and about to order some black dartsImage.
I just received some power door lock actuators, the ones I received are black, that I'm going to use to trigger the blasters, Image. I might even add a single Nerf SuperSoaker Electro StormImage on the front hood of the Batmobile.
Low voltage warning
Building a new pool
Lightning McQueen lowered
