#145976
Newbie here so be gentle! A family member just picked this up (I understand it's an A151 and quite a good bit of kit?) at a sale for £15.00.
Now I know it's missing a few bits, so I need some help!
-My understanding is that it originally had 2 x 6v batteries, but wired to give 12v. Is this correct?
-Are the motors 6v or 12v?
-I was told that having the gear lever in "1" gives 6 to both motors, and in "2" it gives 12v to each motor. Is this right?
-Is it worth swapping the lights to LED? I think all the filament bulbs are 6v?
-What's the best plan with regards to wiring and batteries...is it just worth converting to 1 x 12v?
Assuming I can get it to run, should it have a roll cage too? And seat belts?
Thanks in advance!
Relay parasitic drain?
Upgrading Gator
