#146500
Hi. Purchased Avigo Range Rover Sport 12 Volt Ride On last year and was quite sad when a wheel wasn't spinning, and began troubleshooting. Resolved the issue and quickly learned that my kids (and also me) wouldn't be happy with the stock setup. I proceeded to modify:
Velcro to keep doors closed.
Added a lighted on/off switch instead of simply connecting the wires.
Added a switch (reverse wiring) to allow for two separate power sources. First power source is the stock battery. Alternate power source (I call turbo) goes to 3 NIMH 8.4v RC car batteries (25.2v) - Primarily used to climb the hill in the yard.
As part of modifying the alternate connection, also modified the back panel so it comes in and out with velcro for easy access to the RC batteries, and the connection for charging the stock battery. Will have to post some photos.
Everything works good, but my kids see quite sluggish performance with the stock battery, so the next mod will be to replace the stock 12v with 3 6v for 18v power in the primary power switch position.
#146513
Here is the back panel, which was screwed down. I modified it by cutting, and velcroing so I could easily access below (see below photos).
Also a view with the panel removed. Attached an unused kids kitchen tray thing to use as the RC battery compartment. Also routed the primary power source wire here, and used the original fiber connector for easy disconnect and connect to charge. The RC batteries just come out to charge.
#147248
I'm hoping you can help me. I have the same car but by Famosa. The Gear box is not available on any website and when I took it apart I see the problem is that the gear that connects the motor to the gearbox is broken. Any ideas how I can get another gear?
You can see the motors here, the silver 8 tooth gear that is on one motor is missing on the other. This is the part I need.
specs:
Famusa Feber Range Rover Sport
RFC-IEU030805UU0
8008662-80011495-102014
Gear box
Rel.1360 12-6v
IT00091106
Chengfeng Motor 6v dc
A06-5th1014
200017470
480931
By Avigo Range Rover
#148804
I bought the brake reduction module from ML toys because I upgraded the motors to 550s and increased the batteries to 18v. However, does anybody know which of the 5 wires coming from the pedal i should install it on?
#148842
Avigo Range Rover wrote:I bought the brake reduction module from ML toys because I upgraded the motors to 550s and increased the batteries to 18v. However, does anybody know which of the 5 wires coming from the pedal i should install it on?
It won't work on this type of ride because they have a circuit board controlling the motors rather than mechanical switches.
#148854
Avigo Range Rover wrote:Okay thanks Toy Crusher! Is there anything I can do with this type of set up then to lessen the beating the gear boxes are taking from the constant hard stops every time he lets off the accelerator?
There isn't an easy answer with these circuit board style rides. The best mod that you can do really is a complete one. It's a conversion to variable speed pedal and a scooter motor controller. East Coast Power Up is a member who sells a very complete and well documented kit for a reasonable price. That gives you better control all the way around while lessening the chance of gearbox carnage. Unless your kids are like mine, they can kill anything! :lol:
Thank you sir! I agree, its very nice to have with[…]
I think that you need to confirm that the batterie[…]
Huffy Lightning Mcqueen
