By Astroman
#146633
Hello I am new member to the forum and have several projects I'd like share and I am knowledgeable about brushless systems and I'm happy to help with questions regarding them.
By Astroman
#146634
I have an early 2000s Barbie Jeep that was given to me many years ago. It has gone through many changes over it's lifetime I ran it stock for a year or two an then it was just too slow. I started by replacing the battery with a lawnmower battery and ran it for a week or so. Then I started boosting the voltage in big steps. I started with adding an 18v drill battery and then I added a second then a third. A total of 66V!!! If it had wings it could fly it could run with a 350 four wheeler. It had two switches to access all that power. Someone left a switch on and it fried the electrical system. Then I put a 32cc gas engine in it which drove a tiller gearbox. The clutch and gearbox went out and it was shelved. A year ago I read about a 6v brushless conversion and thought about how fun it would be to have a 2wd version so I started to research motors and escs
By Astroman
#146635
For those who don't know there are two major categories of brushless motors, inrunner motors which have the coils surrounding the magnets their exteriors are similar to a brushed moto they normally have a higher rpm, and then there's the outrunner motor it is more difficult to use as the magnets surround the coils. The magnets spin a drum which makes up most of the motor's exterior however this motor is cheaper lighter and is three times as powerful as an inrunner of a similar size they normally have a lower rpm but they have tons of torque. However I haven't seen any outrunner brushless swaps.
By Astroman
#146636
So far I have the pinion gears, motors, escs, most of the control system and the cooling system.
By Astroman
#148376
I have been waiting on parts almost done will post pictures.
By Astroman
#148377
Will be pushing out ~1hp
