By bmoorelive
#150823
I picked up a used Peg Perego Gaucho Grande for $75. The body is great. I’m having trouble keeping it running because of what seems like a motor or gearbox issue. I recently replaced the passenger side gearbox and motor with a brand new oem part. I’ve inspected both gearboxes and no teeth are damaged on the motor pin or the individual gears within the box.
I’ve added video [/url] of the following observations and events that take place:
1) In high gear, only one motor spins(the passenger side). If the left motor is connected, both motors will run for a few seconds until the breaker is tripped.
2) The left wheel/driver side, seems to want to spin but just vibrates, at a time when both motors were connected and working properly.
3) no motors work when the low gear or reverse is selected.
4) when the gaucho runs, the working tires struggles some on incline.
5) I’ve got a suspicion that the gearbox/frame may not be syncing well with the rear inner hub due to wear on the gearbox on the hub?
CJB Performance HELP/SUPPORT
emailed you.
Perego power connector
