By wesleyb82
#131127
I have not used these but in related news traction on the rear wheels will typically result in gearbox destruction and another option to explore is using BMX tires for front wheels- get a tire size that matches your wheels, cut off the sidewalls, then stretch the tire over and use small screws every few inches to keep the tires from sliding off
I got a Peg Perego RzR 900 12V used from a co-work[…]
battery problems
Hello everyone, I have a question about the batte[…]
https://www.manualslib.com/manual/758928/Kidtrax-[…]
Usually, USUALLY two motors/gearboxes is a good in[…]
