By M.L.Toys
#137539
CHANGES TO STAGED GEARBOXES:
We've made some changes to our Staged kits in response to requests from you guys:
Stage I and III Kits have dropped in price!
Stage I Kits now include the option for Heat Sinks to help motor longevity at 18 volts (which was previously the Stage II kit but at a higher price).
Stage II Kits now include our Hardened Steel First Gears, Ball Bearings, Hardened Steel Pinion Gears, and Race Grease.
http://www.mltoys.com/Performance-Motor ... -s/110.htm
Still no failures of steel first gears In the last 2 production runs (going back as far as last August). Further, No failures have been reported of any kind in gearboxes using our newest generation of steel first gears. Meaning no failures of 2nd, 3rd, or final drive gears. I'm sure at some point someone will add tank treads to them and manage to kill a set. But so far so good.
Clutch system for 7R gearboxes still in development.
Simple soft start esc?
Gaucho's Upgrade
