By ms1120
#51284
I found a spring that is locally available and will not make you rob all of your click type ink pens at work or home. Its a NAPA part number 770-2100. Its marketed under their Balkamp line of parts. They are a little heavier than stock but are exact in their diameter and are long enough to cut in half and make 2 switch springs for PWs or Pegs. Heres a link to the NAPA page for the spring.
http://www.napaonline.com/Catalog/Resul ... 1&Dp=3&N=0
By imickey503
#116914
Thanks! Man I really could of used this a while ago.
Simple soft start esc?
Gaucho's Upgrade
