#58092
I have what I believe to be considered an "old style" JD Gator (OD0004) that is need of a new battery. I have been out of this for so long that I am inquiring about battery options. Do I need to go directly to the supplier or is there something I may be able to locate and purchse from a more readily available retailer, etc? Any help would be greatly appreciated.
Thanks!
Simple soft start esc?
Gaucho's Upgrade
