This section can be used for members to link all their projects, diagrams, favorties, etc to one place. Please keep titles specific and to the point while including your user name and type of content.
By CJB
#76944
As discussed in a different thread, I'm starting this thread and linking it in my signature. This thread will contain all of the wiring diagrams/circuit schematics I've authored. Perhaps more for my reference than yours, but feel free to check it all out and use one or modify it to suit your needs.
This thread is FOR REFERENCE ONLY. DO NOT POST COMMENTS or it will be all cluttered. :!:
IF YOU HAVE A QUESTION, PM me or start a new thread referencing the diagram in question. If this gets filled up with conversation,. I won't be able to find anything. :geek:
By CJB
#76945
Just what I happen to have available here at the moment:
Wiring diagram for my Escalade EXT
Actually, this doesn't look quite right, but it's close.
Escalade EXT.png (23.55 KiB) Viewed 6714 times
Quick diagram I made someone for a mobile kill switch. (Yes, I know the connector doesn't quite look right)
mobile kill.png (14.71 KiB) Viewed 6714 times
CJB Turbo Timer™ Rev. E
CJB TURBO TIMER_E.png (16.65 KiB) Viewed 6714 times
Diagram on how to connect the Turbo Timer
(Note: For green and orange wire, do not rely on the color. I have mixed that up in the past. The one on the right, nearest 'OUT' is always the ENGAGED wire)
cjb nos wiring diagram.png (63.8 KiB) Viewed 6714 times
By CJB
#76946
few more
This was a diagram I sent to a guy I made this harness for. It's designed to be permanently mounted to the batteries and moved from vehicle to vehicle. Includes Remote Kill, and is turbo ready.
18V HARNESS.png (14.58 KiB) Viewed 6711 times
Quick & dirty diagram of how to hook up a Sho-Me 11.1005SF Controller
Diagram for my Polaris 700
Diagram for the Tinkerbell Ninja
Diagram made for kstorm using charge port, volt meter, Turbo Timer™, and some other items.
Kstorm Rev_F.png (62.63 KiB) Viewed 6711 times
By CJB
#119395
Drawing for Sheridan-
Using the Turbo Timer 3.0 to switch 2 12v batteries from parallel to series via DPDT relay
EDIT: preferred set-up would include an accessory 12v battery. I personally like to use my drive batteries for drive only and power ALL other crap (lights, horns, relay coils, etc) off a separate battery. This simplifies (for me) wiring, troubleshooting and charging.
Dale Jr. Power Wheels 12v
Got it all hooked up and works like a charm.
