By sall
#134350
I am getting ready to mount the steering actuator and LAC once it arrives this week on my RC Jeep project. I am curious if anyone who has used the Firgelli actuators have used a step-down to power the actuator and LAC. This on a 24V setup(2x 12V/12aH). I have a 24V to 12V 5A step-down and the max draw of the actuator is 3A @ 12V. I would rather not run another battery for the actuator and don't see why the step-down would not work but looking to hear other's experiences. Thanks.
By sall
#134365
Because that actuator probably draws a lot more than 3 amps under load. Likely gonna need a much larger reducer, like this one:
http://www.ebay.com/itm/Waterproof-24V- ... 20f3956e3b
The datasheet looks like it maxes out at 3A. Robotshop specs on the webpage state 4A.
http://www.robotshop.com/media/files/pd ... 5-12-2.pdf
By sall
#135244
So, a few weeks into a working setup here. I notice when under heavy loads or batteries getting slightly low the actuator becomes sluggish or some times unresponsive. I am assuming the motor draw is causing the LAC to be under powered. Does this sound about right? Only conclusion I can think of. I am using a 24 to 12v 10A stepdown with nothing else powered from it.
Over My Head
It's going to be hard to accomplish what you want […]
FS: OEM Chargers
Hi how much for the lot shipped to Zip code H3M 1T[…]
No problem. I sold all of my old tail light lense[…]
