By kaplooi
#136398
So I have a Jeep Raptor/Drifter RC car that came with remote steering and throttle from the factory, but the steering H Bridge IC has (partially) failed and it only steers in one direction so I've decided to scrap the stock controller and fit RC components so I have fully proportional throttle and steering control. The twist is that I also want to fit a PWM throttle pedal connected to a separate controller that I can toggle on/off with an RC switch on a spare channel to enable remote override. It's wired to give power to the on board PWM controller so a child driver doesn't need the RC signal to drive. Remote steering control will always be enabled, but a relay will switch power between the two escs. I've included isolation relays to prevent current flowing from one controller's PWM output to the other which would probably destroy both. I don't think a relay cares what sort of signal it's switching. Does it matter that the polarity on the relay isolating the RC ESC will reverse depending on forward/reverse input? The coil wiring will not be reversed. Will the wiring detailed below isolate the two controllers adequately?
Lightning McQueen lowered
Unibody Jeep Stock Lift
Stock lift for unibody jeeps
The Barbie Jeep make over
