By islah
#140580
This is mostly just a custom paint job. My process is: take apart, light heat gun, sanding, prime w/ rustoleum 2x plastic spray paint, paint w/ the same -- the detail is done in acrylic atop spray paint, then used gloss clear top coat (also rustoleum).
These little peg perego / john deere vehicles are a little trickier to pry apart than your standard power wheels. You gotta open up the bottom to unscrew the seat, and lot of pressure-fit pieces you really have to pull at or pry with a screw driver.
But picked this up at a flea market for $60 so good deal!
Finally added umbrella for fun in the sun. Easy to adhere this type of plastic to pvc pipe using plumbers putty... which is also paintable.
#140584
Wow! I've never seen anyone do something like this with a John Deere. It's, different. Good job
Agreed, that is unique and looks great. I second the question on the tires, is that spray on bed liner?
Battery spark when connecting.
1. That wiring doesn't look capable of handling th[…]
Gaucho Grande gearboxes
