By JamesC737
#146044
Hey guys,
First time doing a mod. Just wanted to know if anyone has added the ML Toys Emer lights to anything and if so, how they did it. I'll be adding these and a siren to a KidTrax Police Car. Any help is much appreciated!!
James
By MacroscopePilot
#147815
I just bought a set of them for my Commando jeep that will become a Military Police vehicle
I think the only tricky part will be mounting the controller box, as it's pre-wired and ready to go
of course finding a good way to run the wires safely, and i a way you can still disassemble the car....
By M.L.Toys
#147821
You can mount the control box with double-sided tape or glue. Drill small holes in the body wherever you need to run a connector though. If you want make smaller holes you can remove the wire ends from the white connectors by using an eyeglass screwdriver to pop the brass tabs out of the connectors. Just be sure to first mark which side of the connector gets a red wire and which gets black. Feel free to email directly with any questions for faster responses mltoys.com@gmail.com
The Stage IV Motor/Gearbox kit is your best bet fo[…]
Starwars X-wing fighter gear box?
Hi, I have a striped gear in my son's X-wing fight[…]
Sportsman Twin 700's seem sluggish
I have 2 Peg-Pergeo Sportsman 700's. Both have ne[…]
